DFM check: Is this part a "nightmare" to machine?
Hi! Designing a custom housing for a prototype. I’ve got features on all six sides, and I’m realizing this is going to need a ton of CNC setups. In your experience, is it better to design for manufacturing by splitting the part into two bolted components, or does the extra assembly time usually cancel out the savings from fewer CNC setups? What’s the “rule of thumb” for when a part becomes too complex for a single block?
1.5k
Mar 16
Dec 29
2.2k
Nov 25
Hi! I’m working on a compact linear slide mechanism for a handheld inspection tool. The carriage rides between two vertical guide rails and has to remain laterally constrained while still moving smoothly along the... read more
Sep 30
Slim linear guide for precise lab automation stage
I’m designing a compact linear stage for a lab automation setup, used to move a microplate (about 300 grams) precisely along a 150 mm travel. The system needs to achieve repeatability under ±0.05 mm... read more
1.9k
Sep 02
