DFM check: Is this part a "nightmare" to machine?
Hi! Designing a custom housing for a prototype. I’ve got features on all six sides, and I’m realizing this is going to need a ton of CNC setups. In your experience, is it better to design for manufacturing by splitting the part into two bolted components, or does the extra assembly time usually cancel out the savings from fewer CNC setups? What’s the “rule of thumb” for when a part becomes too complex for a single block?
      That’s a great question – this is where design intent collides with the reality of manufacturing. If you find yourself in a tightly controlled 5-axis process with 3-4 orientations, that’s normal. If you’re dealing with 6+ rotations using soft jaws, resetting references, and creative fixturing, that’s when cost and tolerance stack-up start to increase.
      There’s no hard and fast rule, but here’s a practice: if you’re creating special devices to access features – and these devices are more costly than the assembly hardware – it’s time to rethink the part division.
    • Sealing and IP Rating: If the enclosure needs to be waterproof (IP67+) or airtight, a single piece eliminates leak paths.Structural Integrity: For high-vibration or high-stress environments, a single block is inherently stronger.EMI/RFI Shielding: Fewer seams mean better electromagnetic interference protection.Precision: If features on opposite sides have extremely tight tolerances relative to each other (e.g., $< pm 0.02$ mm), machining them in one part (using a 5-axis machine) is more accurate than trying to align two bolted parts.
W
1.9k
Mar 16
3.1k
3.3k
2.6k
