Hi!
I’m working on a compact linear slide mechanism for a handheld inspection tool. The carriage rides between two vertical guide rails and has to remain laterally constrained while still moving smoothly along the axis. The lateral clearance is only about 0.5 mm per side, and the environment involves frequent handling and occasional shock loads.
I’m trying to figure out the most reliable way to get both low-friction movement and minimal lateral play, without using bulky linear bearings. At this scale, is there a preferred approach, like small-diameter side rollers, polymer wear strips, or interference-fit guide blocks, that balances smooth travel with side-load resistance?
      Hi!
      Cool project! With such tight space, your options are limited, but definitely workable. I’d lean toward polymer wear strips, PTFE-filled nylon, or UHMWPE inserts on the carriage. They give you low friction, can be preloaded slightly to kill backlash, and tolerate shock.
      Wear strips don’t necessarily generate too much drag over time if you choose the right material. PTFE blends self-lubricate and hold up surprisingly well in handheld devices. You’ll just want a smooth rail surface finish and maybe a light dry-film lubricant.
W
Mar 16
Dec 29
2.3k
Nov 25
