Sheet metal hem
s
Hello, I’m trying to create a hem on the edge of steel sheets between 200mm and 400mm long. I can’t find any manufacturer in France who can perform such bending/rolling/shaping with a radius of 3.5mm for a 15/10 sheet.
Do you have any ideas?
Thank you
