Hello, I am currently working on the design/manufacture of a half-handlebar for a sports motorcycle (GSXR 1000). What is the best type of process that I could establish for the manufacture of the handlebar (with aluminum as the material)? Is it preferable to opt for die casting or sand casting? This is without taking into account a target quantity while maintaining a reasonable manufacturing cost. Thank you
Scanning and Printing
Jul 17
1.5k
