Hey! I have FDM-printed ABS bracket for an industrial sensor mount that’s fixed to aluminum frame using M4 screws. The part sees light vibration and occasional re-torquing during maintenance. I’m considering switching from self-tapping to inserts, but I’m concerned about layer separation and insert pull-out. For this kind of load case, have you found better results by changing print orientation or insert type to improve long-term reliability?
Scanning and Printing
Jul 17
1.4k
