Hey! I have FDM-printed ABS bracket for an industrial sensor mount that’s fixed to aluminum frame using M4 screws. The part sees light vibration and occasional re-torquing during maintenance. I’m considering switching from self-tapping to inserts, but I’m concerned about layer separation and insert pull-out. For this kind of load case, have you found better results by changing print orientation or insert type to improve long-term reliability?
      Yes, heat-set inserts usually beat self-tappers in ABS. The main failure mode I see isn’t the insert itself; it’s the printed “shell” splitting along layer lines because the hoop stress from the insert is fighting Z-strength. If you can, print so that the insert axis is parallel to the layer planes. If the insert is vertical in Z, the expansion during setting and the torque load tend to pry layers apart. I’ll often rotate the bracket so the boss is “lying down” and then add support – ugly, but much stronger.
Scanning and Printing
Jul 17
2.3k
