Good afternoon,
Does Xometry perform welding work such as sealing the folds of a box-shaped design?
Can Xometry weld a nut, for example an aluminum DIN934, onto an aluminum sheet?
Best regards
Automatically translated from: Español
    • j
      Good afternoon,
      Best regards
      Hi Jose,
      Yes Xometry can perform welding job. In order to do the job correctly, you should provide us a drawing with all the welding specs you are looking for.
      Hi Jose,
      Indeed, Xometry is capable of executing welding operations. To ensure it’s done accurately, it would be helpful if you could provide us with a detailed technical blueprint that identifies and specifies all the welds you wish to incorporate.
Scanning and Printing
Jul 17
1.4k
