s
Hello, I was wondering if there would be any issues in requesting the production of a print from a model purchased from a third party.
Thank you and keep up the good work!
    • s
    • Good morning dear user, does your question concern any copyright issues?
    • s
      Hello and thank you for the response.
      Exactly; protections, licenses and copyright.
    • This is a rather delicate matter. We can manufacture these products for you, but you will not be able to resell them to third parties. If you do, you would be committing a copyright infringement.
    • s
      Very clear, thank you.
      In the description of the file for sale, it is specified that resale is prohibited unless authorized by written consent.
      In any case, I would be interested in producing a print of a life-size lion skull.
      The volumes are quite complex, I would need high definition and a smooth finish.
      Next month I will send you a link to the 3D model for sale to give you a more precise idea and recommend the most suitable type of printing and material.
      In the meantime, thank you for your availability, good work!
Scanning and Printing
Jul 17
1.4k
