Embossed vs. engraved text for outdoor molded parts
Hi there, I need to add a part number and recycling symbol on the surface of molded parts in PP GF20 for outdoor use. I initially planned to use engraved text for aesthetic reasons, but I’m concerned about visibility and tool wear over long production runs. Would embossed text (raised on the part) be a better option here in terms of durability and legibility? The surface finish is light matte, and cycle times are tight, so I’m also considering mold complexity.
2.0k
2.8k
2.8k
Dec 23
