SLA material for outdoor indicator lenses
hi, I’m recreating two small indicator lenses for a 1980s motorcycle restoration. These need to be clear, UV-stable, and able to handle exposure to sun and rain long-term. I’m planning to go with SLA for surface finish accuracy but unsure which resin would offer the best optical clarity and weather resistance without yellowing. Anyone tested something that holds up outdoors over time?
Title: How to build a smartphone from scratch (parts & assembly) Description: Hello, I want to build a smartphone from scratch as a learning project. Can you please provide: – A full list of required components (mainboard, display, battery, cameras, etc.) – Recommended models or compatible parts – Estimated prices for each part – Step-by-step instructions on how to assemble them I am a beginner but I have basic experience with phone repair. Thank you!
Title: How to build a smartphone from scratch (parts & assembly)Description:Hello, I want to build a smartphone from scratch as a learning project.Can you please provide:- A full list of required components (mainboard, display,... read more
May 05
2.3k
Surface Finish
Jan 21
