Title: How to build a smartphone from scratch (parts & assembly) Description: Hello, I want to build a smartphone from scratch as a learning project. Can you please provide: - A full list of required components (mainboard, display, battery, cameras, etc.) - Recommended models or compatible parts - Estimated prices for each part - Step-by-step instructions on how to assemble them I am a beginner but I have basic experience with phone repair. Thank you!
Description:
– A full list of required components (mainboard, display, battery, cameras, etc.)
– Recommended models or compatible parts
– Estimated prices for each part
– Step-by-step instructions on how to assemble them
Thank you!
2.3k
Surface Finish
Jan 21
Dec 17
