Fuel-resistant material for 3D printing
Hi! I’m restoring an older two-stroke motorcycle and need to replace a worn-out venturi nozzle that draws in fuel-air mix. I’m considering having it 3D printed, but I’m unsure which material would best hold up to long-term gasoline exposure and engine heat (ambient temps around 70–90°C, possibly higher during load). Mechanical stress is low, but it needs to be tough—not brittle—and resistant to swelling or degradation over time. Thanks
Title: How to build a smartphone from scratch (parts & assembly) Description: Hello, I want to build a smartphone from scratch as a learning project. Can you please provide: – A full list of required components (mainboard, display, battery, cameras, etc.) – Recommended models or compatible parts – Estimated prices for each part – Step-by-step instructions on how to assemble them I am a beginner but I have basic experience with phone repair. Thank you!
Title: How to build a smartphone from scratch (parts & assembly)Description:Hello, I want to build a smartphone from scratch as a learning project.Can you please provide:- A full list of required components (mainboard, display,... read more
May 05
2.3k
Surface Finish
Jan 21
