I’m designing a protective enclosure for an outdoor sensor unit in SolidWorks, and I need to estimate how much polyurethane coating I’ll need. When I use the Evaluate – Mass Properties tool, it seems to include all internal faces of the assembly, which throws off the paint calculation. Has anyone found a reliable way to get only the external, exposed surface area of an assembled part? Any workflow tips would be really helpful.
Thanks in advance!
Sourcing Cad Designer
Nov 10
5.6k
Jul 02
7.0k
Jul 03
