Using generative design tools in Fusion 360
Hello everyone, I’m working on optimizing the weight/strength relationship for a bracket component in an aileron actuator. I’m using generative design tools in Autodesk Fusion 360. Can anyone guide me in setting up generative design studies?
Sourcing Cad Designer
Nov 10
1.7k
6.0k
Jul 02
