hi, for a welded steel coolant reservoir for a test stand – 4 m × 2 m × 1.5 m with internal bracing I need to account for thermal expansion. Fluid runs at 80–90 °C and then drops to ambient. Before I build load cases for the shell and stiffeners, how detailed must the thermal input be? In practice, do you assume a uniform ΔT and check self-straining forces, or do rectangular tanks with internal bracing usually require a more detailed temperature distribution/FEA?
2.9k
2.2k
Dec 23
3.2k
Dec 29
