Using generative design tools in Fusion 360
Hello everyone, I’m working on optimizing the weight/strength relationship for a bracket component in an aileron actuator. I’m using generative design tools in Autodesk Fusion 360. Can anyone guide me in setting up generative design studies?
Apr 28
Solidworks
Apr 14
STEP or IGES?
Hi! I’m preparing to send a CAD file to my manufacturer for a CNC-machined aluminum enclosure. Would it be better to use a STEP or IGES file to send to the manufacturer? The design... read more
