Verifica dei guasti nelle matrici e nei fissaggi
Salve, sto lavorando alla progettazione di matrici e fissaggi e sono curioso di sapere quali sono i modi migliori per prevenire guasti. Quali metodi o software utilizzate per i vostri progetti? Ho sentito parlare delle simulazioni FEA, ma ci sono impostazioni specifiche o tipi di analisi più efficaci? Inoltre, come gestite i test effettivi per individuare i problemi che le simulazioni potrebbero non notare? Qualsiasi consiglio o esperienza condivisa sarebbe utile.
Risolto daJoao Clemencio
Hi Massimo,
Honestly at Xometry we are focused mainly on manufacturing processes and we don't do enough product development to be experts on the questions you are doing.
Even so, when designing dies and fixtures, preventing failures is crucial. I recommend using FEA simulations to predict stress points and deformations before manufacturing.
Focus on realistic boundary conditions, non-linear analysis for complex interactions, and fatigue analysis for parts under repetitive loads. There are several tools available on the internet to do it.
However, since simulations can't catch everything, it's essential to do prototype testing under real-world conditions to validate your FEA results and identify any issues the simulations might miss. Iterate between simulations and physical testing to refine your design and catch potential failures early.
      Hi Massimo,
      Honestly at Xometry we are focused mainly on manufacturing processes and we don’t do enough product development to be experts on the questions you are doing.
      However, since simulations can’t catch everything, it’s essential to do prototype testing under real-world conditions to validate your FEA results and identify any issues the simulations might miss. Iterate between simulations and physical testing to refine your design and catch potential failures early.
      Ciao Massimo,
      Onestamente noi di Xometry ci concentriamo principalmente sui processi di produzione e non ci occupiamo abbastanza di sviluppo del prodotto per essere esperti delle domande che stai facendo.
      Tuttavia, quando si progettano stampi e attrezzature, la prevenzione dei guasti è fondamentale. Consiglio di utilizzare le simulazioni FEA per prevedere i punti di stress e le deformazioni prima della produzione.
      Concentratevi su condizioni al contorno realistiche, sull’analisi non lineare per le interazioni complesse e sull’analisi della fatica per i pezzi sottoposti a carichi ripetitivi. Su Internet sono disponibili diversi strumenti per farlo.
      Tuttavia, poiché le simulazioni non sono in grado di cogliere tutto, è essenziale eseguire test sui prototipi in condizioni reali per convalidare i risultati FEA e identificare eventuali problemi che le simulazioni potrebbero non cogliere. Alternate le simulazioni e i test fisici per perfezionare il progetto e individuare tempestivamente i potenziali guasti.
Dic 11
Apr 22
Apr 16
