Wall thicknesses for SLA (100 mm high) - any tips?
Hi everyone,
I am working on an SLA 3D printing project with parts where my internal walls that need to be about 100 mm in height. Looking for advice on the optimal wall thickness to avoid warping and internal stress. What’s the minimum recommended thickness for such a wall? Any specific experiences or other guidelines would be greatly appreciated!
Solved by Nikolaus Mroncz
Dear Kris.Mel, thanks for your question. In SLA we recommend a wall thickness of min 0.6mm for unsupportive walls. More information you can find here:   https://staging.xometry.pro/en-eu/articles/3d-printing-sla-design-tips/ https://staging.xometry.pro/en-tr/articles/3d-printing-design-rules/
    • K
      Hi everyone,
      Dear Kris.Mel,
      Stereolithography (SLA) 3D Printing Design Tips
      Infographic: Design Rules for 3D Printing
      • K
        Nikolaus Mroncz
        Thank you, that’s helpful!
Wall thicknesses for SLA (100 mm high) – any tips?
5
Dec 11
FEA of a welded tow hitch
Apr 16
Mar 31
