The best 3D printed material for bicycle handlebars
In my current project, I need to develop a durable and flexible bicycle handlebar using 3D printing technology. What is the most durable 3D printing material, able to mimic the properties of a carbon fiber bicycle handlebar (therefore able to be strong, shock-resistant, and not deform or break under heavy stress)?
Solved by Giuseppe Pestrin
Good morning, considering the conformation of the piece to be produced, the stresses it should withstand and the production characteristics of 3D printing, unfortunately there are no materials available (for this production technology) that match the characteristics of carbon fiber
    • G
