STEP or IGES?
Hi!  I’m preparing to send a CAD file to my manufacturer for a CNC-machined aluminum enclosure. Would it be better to use a STEP or IGES file to send to the manufacturer? The design has some tricky features like internal ribs and threaded holes, so I want to make sure everything comes through accurately. I’m leaning towards STEP, but I’d love to hear what others prefer and why.
    • F
      Hi Franz, STEP is definitely the way to go for a CNC-machined part, especially with intricate details like internal ribs and threaded holes. It keeps the solid body data intact and handles features like threads, fillets, and complex surfaces way better than IGES. Plus, it plays nicer with modern CAM software like Fusion 360 and Mastercam.
      Also, might be worth checking with your manufacturer on whether they prefer modeled threads or just hole callouts. A lot of CNC shops lean towards hole annotations instead of modeled threads since it keeps things simpler in CAM. Hope that helps!
      Hey Franz, just a heads-up—IGES files tend to turn solid bodies into surfaces, which can be a pain when importing into CAM software. You might end up with gaps or missing faces, especially in tricky spots like ribs and threaded holes. Unless your manufacturer specifically asks for IGES, definitely stick with STEP. It’ll save you some headaches
STEP or IGES?
New topic
link  edit  https://www.figma.com/design/YTBLdcjRXWn
Jul 31
Apr 28
Solidworks
Apr 14
t
I Want to Be a Supplier
We want to produce and sell products using our 3D printer.On the test piece you requested (part number: 281893), the filament you want us to use is PA-12.However, we cannot procure this product. Due... read more
Mar 05
