Shore A Elastomers for High Pressure Seals
Hello everyone, I am working on a project that requires the selection of the right elastomer for a seal. I am trying to understand how the Shore A hardness scale influences the flexibility and durability of the material. Can someone explain to me how to choose the Shore A hardness for seals intended for high pressure environments? Thanks!
