I’m working on a small gear-driven mechanism for a camera panning rig and considering printing the 45° bevel gears in PETG (FDM). Tooth pitch is 1.5 mm, and the gears will be rotating slowly under low torque. My concern is whether layer lines and over-extrusion could cause poor meshing or increased backlash, especially since the gears need to run smoothly for accurate motion control. Would post-processing like sanding the teeth tips make a noticeable difference?
Moulding of a Concave Disk
Best process for small stainless steel tiles
hello, my project requires the production of small metal tiles (approx. 50 mm x 50 mm) for decorative and functional purposes. The tiles need to have sharp, well-defined edges, a smooth surface finish, and... read more
Mar 07
