MEI industry pieces
mei
Solved by Manon Bouriaud
Hello Benjamin,
Do you have a question to ask? It seems that your message has been truncated, and in its current state it is not very useful to the Community.
    • mei
    • Senior Content Manager
      Hello Benjamin,
    • A glass plate and give it a shiny effect.
    • Perfect!
MEI industry pieces
