Materials suitable for snap-fit features in 3D printing
8
Hi community, can you suggest any 3D printed materials that would work best for a “snap-fit” feature?
Solved by Robert K.
Thank you, Nikolaus! And would PETG be a suitable option as well?
      Hi Robert, sure.
      PA12 or PA11 in SLS or MJF works best here. PA11 is the more durable of them.
      BR
        Nikolaus Mroncz
      PETG is a strong material and also good in elongation at break, but be aware that in FDM the properties in Z – direction are always weak. So in practice, it would be not so much dependable and weaker in Z- direction then the suggested above.
        Nikolaus Mroncz
        thanks, appreciate your response!
