Fault checking in matrices and fixings
Hello, I am working on the design of matrices and fixings and I am curious to know what are the best ways to prevent faults. What methods or software do you use for your projects? I’ve heard about FEA simulations, but are there specific settings or types of analysis that are more effective? Also, how do you manage actual tests to identify problems that simulations might not notice? Any advice or shared experience would be helpful.
5
737
Dec 11
FEA of a welded tow hitch
Apr 16
Mar 31
