Deep pocket/cavity - CNC machining
Hi everyone,
I understand that there are limitations on the depth of cavities, and it’s generally recommended not to exceed a depth-to-width ratio of 4:1. However, I have a design that requires a pocket/cavity with a depth about 7 times the width. Could someone recommend any design strategies to achieve this while still allowing it to be milled? I know about using stepped pockets, but my design requires a flat bottom. Any advice would be appreciated!
5
1.4k
Dec 11
FEA of a welded tow hitch
Apr 16
Mar 31
