Hi,
Working on a compact gearbox for a robotic arm and need advice on the best gear setup. The arm sees intermittent loads, max torque at the output is 15 Nm, and I need about a 25:1 reduction. Space is tight, so I’m debating between a planetary system or a helical-spur combo. Priority is low backlash, even load distribution, and durability while keeping it manufacturable.
Would a planetary setup handle varying loads better, or is a helical-spur mix a smarter choice for efficiency and longevity?
      Hi,
      We’re gonna need a bit more detail about the robotic arm you want to build – how big is it? What material are you going to use? What do you mean by tight space, how tight?
      Both the types of gearboxes you’re thinking of can work well, and both have been used in industrial robotic arms. You list a lot of things you want the gearbox to have (low backlash, even load distribution, durability, etc) – in my mind, the planetary gearbox wins in most of those categories. The helical-spur combo is more easily manufacturable, but a planetary gearbox is not that hard to manufacture, so I think it still ticks all your boxes.
    • For your compact robotic arm gearbox (15Nm, 25:1 reduction), planetary gears are superior for your requirements:
      Low Backlash: 3-5 planet gears share load, achieving ≤5 arc-min backlash (vs. 10-15 arc-min in helical/spur combos);
      Load Distribution: 150%+ higher torque density with balanced tooth contact pressure;
      Compactness: Single-stage planetary achieves 25:1 in 40mm axial space (helical/spur needs 2 stages, 60mm+);
      Shock Tolerance: Multi-tooth engagement handles intermittent loads better (FEA shows 30% lower peak stress vs. helical).
      Critical Notes:
      Use 20CrMnTi steel with case hardening (HRC58-62) for pitting resistance
      Optimize carrier pin tolerance (H6/h5) and preloaded angular contact bearings
      Avoid: Plastic gears – fatigue failure risk at 15Nm cyclic load
      Example: Harmonic Drive®-style compact strain wave achieves <1 arc-min backlash, but planetary offers better cost-efficiency for prototyping.
5
Dec 11
FEA of a welded tow hitch
Mar 31
Deep C-channel in 2 mm stainless
Hi all, working on a sheet metal design and trying to form a C-channel in 2mm stainless (304). The depth is 50mm, and I’m wondering if I’m asking for trouble with bending—springback, cracking, or... read more
