Vapor smooth very thin parts?
Hi, I’m working on a project that involves very delicate, thin-walled MJF 3D-printed parts, and I’m considering vapor smoothing to improve surface finish and aesthetic quality. My main concern is whether the process could cause warping or damage to such thin structures. Does anyone have experience with vapor smoothing on parts with extremely fine geometries, and are there any specific precautions or alternatives I should consider?
