en – UK
Europe Europe
Türkiye Türkiye
United Kingdom United Kingdom
Global Global
Uniform surface finish on aluminum sheets
Hello, I need an aluminum sheet with a perfectly even surface finish since the final look is really important. The problem is, the sheets I’ve used so far have darker stripes or uneven patterns, which won’t work. Has anyone dealt with this before? Would foil sheets or pre-finished aluminum be a good option, or is there a better type of aluminum sheet I should look into?
    • v
      Those darker stripes or patterns are typically a result of the rolling process during production. Where consistency is critical, pre-finished aluminum or anodized sheets are options for better results, depending on your requirements. Pre-finished sheets come with a factory-applied coating, like paint or laminate, or sometimes alodine/anodizing. They’re ready to use and available in a huge range of colors and gloss/matte finishes. Anodized or alodined aluminum undergoes an electrochemical process that either thickens the natural oxide layer on the surface or adds a chromate layer. Both give a uniform, durable finish while enhancing corrosion resistance. Anodized finishes can also be dyed because they’re porous, but they’re less flexible in terms of texture or pattern compared to pre-finished sheets.
        vittorio canale
        Would either option handle minor scratches or dents better?
