Surface roughness in 3D printing
What is the average surface roughness of different additive manufacturing processes? I’m mostly interested in SLS and MJF, is there is a big difference between these two? I couldn’t find much on this topic so any feedback would be very much appreciated
Apr 25
Moulding of a Concave Disk
