SLA Printing: Is manufacturing a large soft robot possible?
Hello! I’m planning to manufacture a soft robot from flexible material, either silicone or Formlabs Flexible 50A Resin, with dimensions of approximately 45 cm in width, 30 cm in depth, and 30 cm in height. Could this be achieved within the scope of flexible SLA printing? What are the maximum dimensions possible for flexible SLA printing?
Solved by Nikolaus Mroncz
Hello Max,
unfortunately, it's not possible to represent such large parts with flexible materials like Flexible 50A. The material is suitable for the machines Form 3 and Form 4. Form 4 is the larger one and measures 200x125x210mm, which I also see as the maximum. VG
      Hello Max,
      unfortunately, it’s not possible to represent such large parts with flexible materials like Flexible 50A. The material is suitable for the machines Form 3 and Form 4. Form 4 is the larger one and measures 200x125x210mm, which I also see as the maximum. VG
        Nikolaus Mroncz
        Hi Nikolaus, thank you so much for the quick response and clear information! This really helps me in planning my project. Great that you took the time to explain it in such detail. Best regards
        Max
Apr 25
Moulding of a Concave Disk
