Painting recommendations and compatibility for ready-made SLS parts
Hi everyone,
Are the existing SLS 3d printed parts suitable for painting, whether by spray-painting, hand painting, or other methods? Which paint types are recommended? are there any to avoid due to compatibility issues?
