Tips for converting from STL to STEP?
Hello everyone! I would like to convert some complex STL files into STEP for better CAD processing. Which software do you recommend for this? I tried FreeCAD, but I am afraid that details may be lost during the conversion. Are there specific settings or proven procedures to ensure a smooth transition while preserving the completeness of the model? I am thankful for any tips or experiences! Thank you very much!
Solved by Nikolaus Mroncz
Hello Rudolf,
here you will find a guide to convert STL to STEP.
VG
https://www.xometry.com/resources/3d-printing/stl-to-step/
      Hello Rudolf,
      VG
New topic
link  edit  https://www.figma.com/design/YTBLdcjRXWn
Jul 31
Apr 28
Solidworks
Apr 14
t
STEP or IGES?
Hi!  I’m preparing to send a CAD file to my manufacturer for a CNC-machined aluminum enclosure. Would it be better to use a STEP or IGES file to send to the manufacturer? The design... read more
