Thermoplastic elastomer for high-temperature gasket applications
Hello! I am looking for a thermoplastic elastomer suitable for injection moulding to create gaskets for high-temperature applications. The material should have a Shore A hardness of 40-50, a maximum compression set at 120°C and no crosslinking. Can anyone recommend a suitable option?
