The closest material to Delrin for 3D Printing
t
I am working on a lightweight, durable, and low friction coefficient drone propeller. Delrin seems ideal, but we are still in the early stages. Do you have any thoughts on 3D printing materials that we might explore at the prototype stage? What are the materials that are closest in characteristics to Delrin?
Solved by Durmuş Yılmaz
Delrin is often chosen in many engineering applications due to its characteristics such as high durability, wear resistance, and low friction coefficient.
With these features, it can be used in the production of machine parts and gears, and it can also be preferred in the production of sports equipment and prostheses because it can provide durability and lightness at the same time.
There is no 3D printing material that matches all the features of Delrin exactly. However, you can choose materials that offer features close to you according to the following factors:
  • Mechanical Properties:
    Polyamide 12 (PA12): It offers high strength along with good chemical resistance and low friction coefficient. It is a close alternative to Delrin.
    PEEK: Stands out with its high temperature resistance, good chemical resistance, and wear resistance features. However, it is more expensive than PA12.
    PC (Polycarbonate): PC, which offers high strength, good chemical resistance, and impact resistance, can be an alternative to Delrin in some cases. However, it is not as slippery as Delrin.
    ABS (Acrylonitrile Butadiene Styrene): Although it is less durable compared to Delrin, it can be preferred for some applications that can be used instead of Delrin with its low friction coefficient and affordable price. It can be especially used in prototyping.
  • Price: 3D printing filaments are generally more economical compared to Delrin. However, high-performance filaments can be more expensive than standard PLA filaments.
  • Chemical Resistance: It's important to choose a filament that is resistant to the chemicals used in your project. Xometry Turkey can support you on this issue.
  • Surface Quality: You should choose a filament suitable for the surface quality required by your project and keep in mind that the surface outputs of layered manufacturing products will be different compared to CNC processing.
  • Application Requirements: Always keep the unique needs of your project in mind and make your choice accordingly.
We can provide you with more detailed information and material suggestions as Xometry. You can upload your model to the platform or reach us at info@xometry.com.tr for more comprehensive information.
Also, you can find more information about materials and technical specifications from the materials section: https://staging.xometry.pro/tr/malzemeler/
    • t
    • Delrin is often chosen in many engineering applications due to its characteristics such as high durability, wear resistance, and low friction coefficient.
      • Chemical Resistance: It’s important to choose a filament that is resistant to the chemicals used in your project. Xometry Turkey can support you on this issue.
