Moulding of a Concave Disk
Hello everyone, I want to make a disk of 203 mm in diameter, 25 mm in height with a concave curvature of 3.22 mm.
Will this precision be respected knowing that I am not a professional but an individual?
Apr 25
Best process for small stainless steel tiles
hello, my project requires the production of small metal tiles (approx. 50 mm x 50 mm) for decorative and functional purposes. The tiles need to have sharp, well-defined edges, a smooth surface finish, and... read more
Mar 07
