Hello, I need to produce a small housing component for an outdoor sensor unit. I thought MJF could be a good fit for prototyping and potentially low-volume production. The part needs to handle exposure to sub-zero temperatures (down to -20 °C) without becoming brittle while retaining a bit of flexibility for snap-fit assembly. Among the available MJF materials, which one offers the best low-temperature performance combined with slight ductility?
Best injection molding plastic for plastic enclosure
Hi everyone, we’re talking about a snap-fit design for a small electronic enclosure that needs to be opened and closed frequently—about 20 cycles per week. The part should be injection molded, and I’m deciding... read more
Apr 16
