Hey there, I’m designing a flexible watch strap that will be injection molded in TPU (Shore 85A). I want to include some small embossed text (branding and serial number) directly on the strap, but I’m unsure about the minimum dimensions that will mold cleanly without issues like incomplete fill or poor definition. Have any of you had good results with small embossed features in TPU? Specifically wondering what minimum height and width you’ve found to work reliably.
    • n
      I’ve worked with TPU (Shore 90A) before, and embossed text can be tricky. For clean results, I’d recommend keeping the text height at least 0.3–0.5 mm and the line width ≥ 0.25 mm. Anything smaller risks poor fill or blurring, especially since TPU is flexible and can stick in the mold. Remember to consider the draft angle on the text walls to help with the release for demolding.
      Hello, I am designing a watch strap
    • Admin
      test reply
FEA of a welded tow hitch
Apr 16
Mar 31
Deep C-channel in 2 mm stainless
Hi all, working on a sheet metal design and trying to form a C-channel in 2mm stainless (304). The depth is 50mm, and I’m wondering if I’m asking for trouble with bending—springback, cracking, or... read more
