Material to thermally insulate an electronic circuit
I am looking for a material to thermally insulate an electronic circuit inside a box that will be subjected to a temperature of 250 degrees Celsius during the reflow process. The silicone foam I tried failed to maintain the temperature inside the box. Recommendations for an appropriate material?
