Draft angles for master model?
hi, I’m designing the master model for a silicone mold (for vacuum casting) and wondering about the necessity of incorporating draft angles. Is it always required to include draft angles in the design, or are there specific cases where the material properties, mold complexity, or part geometry allow for skipping them? These holes in a cutaway detail are a good example, should I draft or not draft? thank you
Dec 11
FEA of a welded tow hitch
Apr 16
Mar 31
