We need to create a stainless steel structure for outdoor use in a coastal environment, and corrosion is our primary concern. We’re considering coated fasteners but need to understand whether thicker coatings provide adequate protection, and if there are thresholds where the benefits plateau. Does increased coating thickness affect thread engagement or installation torque, potentially impacting performance?
      Thicker coatings do provide better corrosion protection, but there’s a threshold where increasing thickness doesn’t significantly improve performance. The ideal coating thickness is between 5-10 microns. Anything thicker can affect thread engagement and torque during installation. While zinc coatings help with saltwater exposure, their protection diminishes over time. For enhanced durability, consider PVD coatings. It’s always best to use fasteners tested in the specific environment where they’ll be used for long-term performance.
Best injection molding plastic for plastic enclosure
Hi everyone, we’re talking about a snap-fit design for a small electronic enclosure that needs to be opened and closed frequently—about 20 cycles per week. The part should be injection molded, and I’m deciding... read more
V
Apr 16
