Best process to achieve antique brass finish
Hello Community, I’m looking for a finish that closely resembles antique brass—rich, aged tones with some depth and texture, for aluminum parts for a decorative lighting fixture. I’m not sure which method (Electroplating or powder coating with metallic effect?) would achieve the most authentic look while ensuring durability for indoor use. Any tips on surface prep, finishing processes, or suppliers who specialize in this type of work?
