Are vacuum-casting molds always made of silicone?
Hi! My project requires vacuum casting of silicone parts. I have noticed that silicone molds are commonly used in vacuum casting, but I am wondering if they are always the best option. Would there be any issues with material compatibility if I use a silicone mold for casting silicone parts? What about sticking or the curing process being interfered with by the mold? What are the alternatives?
Apr 25
Moulding of a Concave Disk
