Any favorite underrated DFM trick?
Hello! Recently, I’ve been refining some precision features like thread depth, fillet dimensions, and flat-bottomed drilled holes to enhance manufacturability. It got me thinking—what’s your favorite underutilized DFM trick that makes a big difference in your designs or just brings a bit of satisfaction when you apply it? Would love to hear the clever approaches others use to streamline their projects!
Dec 11
FEA of a welded tow hitch
Apr 16
Mar 31
