Vacuum casting for small series: thermoplastics or just thermosetting?
g
I’m exploring alternatives to 3D printing for the production of small series. Can vacuum casting be used with thermoplastics or is it limited to thermosetting materials? I’m looking for ideas and experiences on this.
Solved by Joao Clemencio
Hi Giulio,
In Vacuum casting you inject both thermoplastics and thermosets materials. Have a look below on what standard materials we have available for auto-quote on Xometry platform. You can also have a deep look on the link below:
https://xometry.eu/en/vacuum-casting/
Vaccum Casting Xometry Materials
    • g
      Hi Giulio,
Apr 25
Moulding of a Concave Disk
