Tips on nested files for laser cutting in 5052 aluminum
Hello, I downloaded nested files from the instant quote engine, but it seems that it doesn’t come back much cheaper than if I had imported my files separately. Do I need to correct something to optimize my nested files? I have a laser cutting project with 5052 aluminum (2.5 mm). How can I better design the parts for optimal nesting? What is the recommended spacing between the parts? I’m open to any advice and rules to follow.
Dec 11
FEA of a welded tow hitch
Apr 16
Mar 31
