Tips for converting from STL to STEP?
Hello everyone! I would like to convert some complex STL files into STEP for better CAD processing. Which software do you recommend for this? I tried FreeCAD, but I am afraid that details may be lost during the conversion. Are there specific settings or proven procedures to ensure a smooth transition while preserving the completeness of the model? I am thankful for any tips or experiences! Thank you very much!
Apr 28
Solidworks
Apr 14
STEP or IGES?
Hi! I’m preparing to send a CAD file to my manufacturer for a CNC-machined aluminum enclosure. Would it be better to use a STEP or IGES file to send to the manufacturer? The design... read more
