Thermoplastic elastomer for high-temperature gasket applications
Hello! I am looking for a thermoplastic elastomer suitable for injection moulding to create gaskets for high-temperature applications. The material should have a Shore A hardness of 40-50, a maximum compression set at 120°C and no crosslinking. Can anyone recommend a suitable option?
Solved by Joao Clemencio
Hello Gary,
Best materials you can use according to your requirements are:
- TPEs
- TPV
As they are the ones with biggest resistance to temperature and have the shores you are looking for available.
You can have a look on the datasheets on our website:
https://staging.xometry.pro/en-eu/materials/tpe/
https://staging.xometry.pro/en-eu/materials/tpv-rubber/
    • G
      Hello Gary,
      – TPEs
      – TPV
