The closest material to Delrin for 3D Printing
t
I am working on a lightweight, durable, and low friction coefficient drone propeller. Delrin seems ideal, but we are still in the early stages. Do you have any thoughts on 3D printing materials that we might explore at the prototype stage? What are the materials that are closest in characteristics to Delrin?
